3G $5 fee?
Mable1
Hi, I have a POCO 5G phone and when I checked my IMEI with the Public mobile phone checker, there's a green check mark beside VOLTE.  However I'm getting charged for the $5 3G network fee.
I have the VOLTE option turned on in my setting.  What else can I do to eliminate the fee?  Thank-you.
2 REPLIES 2
hi @ritz82
no point to do this. That is a legit fees
Carriers are allowed to collect that fees and provide full services to compatible phones
slusagm
Check with PM and provide them the screenshot and they will remove the charges
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
