05-27-2023 11:02 PM
What is the difference between 45.00 20 gig and 39.00 20 gig I'm thinking of switching cause I save another 6.00 and I'm on the old rewards seems to good what do you guys think
05-27-2023 11:26 PM
@Cannonman631 wrote:What is the difference between 45.00 20 gig and 39.00 20 gig I'm thinking of switching cause I save another 6.00 and I'm on the old rewards seems to good what do you guys think
Other than price, there is zero difference between these two plans.
05-27-2023 11:12 PM
HI @Cannonman631 you will be on the same reward even you change plan, any plan
The $45 plan is a regular price plan. The $39 is a limited time offer. PM might pull the plan any time. But no worry, once you have the plan, the price will stay.
05-27-2023 11:04 PM
@Cannonman631 do it. Same plan save $6 and keep your current rewards!
05-27-2023 11:03 PM - edited 05-27-2023 11:08 PM
