12-31-2020 12:33 PM - edited 01-05-2022 04:40 PM
Hi,
I wanted to know if the 35$ plan with the 5$ discount is it only for a certain amount of time?
I would change to this one, but would the 5$ discount stop at some point to revert back to 35$.
Thanks
12-31-2020 12:53 PM
Awesome, thanks to both of you for the quick answer.
12-31-2020 12:43 PM - edited 12-31-2020 12:53 PM
12-31-2020 12:43 PM
I think you are from Quebec? Yes, Quebec has the extra $5 off. This is no expiration for that $5 discount
12-31-2020 12:40 PM
@Chuckyy2 wrote:Hi,
Thanks
The $35 plan with $5 discount is only offered in Quebec only. As long as you meet the Quebec residence requirement, you will continue to get the discount.
