2 hours ago
Does this plan can be used to call and use data within US and teritory e.g. Puerto Rico?
13m ago
@Mateng There are two $34 plans both with 50GB data but one is Canada-US and the other is Canada only so be careful to get the right one.
2 hours ago
The $34 Canada/USA 5G plan should work on the T-Mobile network on Puerto Rico. Enable cellular roaming on your phone while you are there.
