05-17-2019 08:43 PM - edited 01-05-2022 07:32 AM
I have a friend that wants to switch 3 phones over to Public Mobile. One for herself and her 2 kids. What is the best way for her to get the refer bonus ?
Can she setup one sim using my refer code, and then the other two phones using that number or does she use my code for a refer on all 3 sim cards.
Is she able to setup one account and activate all 3 sims under that account?
05-17-2019 10:54 PM
Using three email addresses and one credit card to pay works for referrals.... that's what I did.
Hope it works for you!
05-17-2019 09:50 PM
@icewhaler wrote:I have a friend that wants to switch 3 phones over to Public Mobile. One for herself and her 2 kids. What is the best way for her to get the refer bonus ?
Each phone number must be in different account.
She could use you to refer the first account. She can use your account, one of her accounts, or phone number of any Public Mobile account for the second and third account.
Autopay using same credit card for all 3 accounts could cause problems.
05-17-2019 08:51 PM
Yes it will be ok to use your phone number to refer your friend she will have 10$ credit and you 1$ each 30 days After she can take the new number as reference for the next one etc...
Shr need to check if her phone is ok with public mobile with willmyphonework.net. And it need to be unlock. But one account for 1 SIM card. But you can have a same credit card to pay the 3 accounts.
05-17-2019 08:49 PM
Well the first one should be yours, but I think she want to grab the other two. And she defitively need three email accounts.
05-17-2019 08:46 PM
You can only have one email per sim so 3 separate email addresses would be needed one for each account.
