3+3 GB LTE data confusion
Salimcanada
3+3 GB LTE data for 90 days or for each month?
8 REPLIES 8
pakmode
@Acekiller wrote:
You can always request to renew your plan early if you run out of data.
Exactly.
Acekiller
Michael77
You get a total of 6 gigs over a 90 day period.  Use it any way you want.
Salimcanada
Thanks.
cricketfan
3+3 for 3 months (90 days)
You can use all of it in one day or not use it at all in 90 days. You're not restricted to use 1+1 every 30 days.
mimmo
@makkahn28 wrote:
SO, that means, if you have 6GB Total, 2GB per 90 Day
2x3=6
@makkahn28 I think you mean per 30 not 90
@Salimcanada  the 2gb /30 days is an OK way to look at the data,  but in reality you can use the 6gb in the first day or the last day or anything in between.
the best thing to do is to get a data manager app like mydatamanager, it tracks data over 90 days and not per month.
2x3=6
makkahn28
For DURATION of the 90 Days
