10-25-2023
02:24 PM
10-25-2023
06:12 PM
computergeek541
10-26-2023 12:02 AM
send a private msg to CS_Agnet. Your number may not have been ported properly.
I haven't gotten mine solved yet, but i know the issue.
10-25-2023 11:53 PM
How long is a short time. I put my new sim in 24 hours ago and my phone is still not receive verification codes?
10-25-2023 11:52 PM
This is happening to me as well. Have you fixed the issue?
10-25-2023 02:48 PM
i dont have issues with PM since i can get the code via email.
its an issue when i try to login other id's such as my outlook email
10-25-2023 02:47 PM
For example,
when i login to outlook, it required me to receive a code via text and then verify to login.
i dont get the text messeges sent from outlook. The only other option is call to my phone, but that doesnt work either.
Sending regular texts, phone calls, data all work fine.
10-25-2023 02:32 PM
@notWOrking2you tagged CS_Agent. We are not public mobile representatives here on the forum. We are customers like you trying to help one another. Did you mean to private message CS_AGent instead?
What do you mean you need to access your email? Are you not able to get into your email from your phone or desktop?
Short codes can take a bit of time to work when activating a new line with a provider. Hopefully it will work soon.
10-25-2023 02:27 PM - edited 10-25-2023 02:28 PM
If you switched very recently, it will take some time for other companies to 'find' a way to your new number.
If you have issues logging in to PM account and are not getting code to your phone, switch it to email.
Click on: ‘Didn’t get a code’ and you will get more options.
