$24 plan
Gellyb
Hi is there any agent will help me change my plan to $24 plan thank you
Gellyb
True true thank you
clexxi1
Good luck.  I just tried this and got nowhere. I’m changing my $34 plan to the $15 plan as they will not let me get the $24 plan as it’s for new activations only. I don’t need anywhere near 40gb of data and I don’t have 5g speed in my area either so makes no sense to keep this plan. On the flip side the $15 plan is not adequate.  So it’s appalling we can’t get the same plans as new customers. The $24 plan is ideal for me. I’m many others feel the same.
Gellyb
Thank you so much
HALIMACS
@Gellyb
if you’re unable to change your subscription on the self-serve, ask a customer support agent as follows:
To contact a Customer Support Agent, send a private message to the Customer Support Agents by clicking here
You’ll need to be logged into your Community account for the link to work.
