20GB + BONUS 40GB
Ardizi
Hi , I want to buy a plan and transfer from another company to Public. What do you mean when you say:
  • 20GB + BONUS 40GB of data for use within Canada, US & Mexico at 5G speed up to 250 Mbps. Does it mean 60 GB every month during contract period?
slusagm
It's just a fancy way of saying 60GB
And once you joined, it will be 60GB every cycle and not just for limited number of months
Chalupa_Batman
Yes. You will get 60GB of data max every month.
Before you port over your number, I would STRONGLY advise you sign up first with a SIM card you already purchased and then once signed up, make sure you can make and take calls, texting works both ways and data works. This way, if there is a problem of some kind, you won't be stuck without a phone. Then you can log into your account and port your number over. Just make sure your other account you're porting from is active.
