2 factor authentication in Mexico
socanadian
Hello,
I have a public mobile Canadian phone number.   Currently I am in Mexico using a Mexican SIM with a Mexican Phone #.
I need access to an online account of mine that is set up with 2 factor Authentication.
Is there a way I can forward texts from my Public Mobile phone # to my Mexican #?
If not is there another way I can get access to my online account?
Please note, there is nobody I can call to change my 2 factor authorization via phone at the company.
Thanks in advance!
@darlicious i guess you are correct
darlicious
@Quigley @hTideGnow
Lol...I think you are both assuming the OP is asking about their pm account whereas I read the message as an online account other than the pm self serve account ie. like a bank account or Facebook etc....?
Quigley
@socanadian
You'll have to get help with access to your account from a Customer Support Agent.
Use the Chatbot Simon to get a service ticket started.
Or send a private message to CS_Agent
darlicious
@socanadian
Do you have the option to send the 2FA code by phone call to your pm voicemail rather than by text message?
hi @socanadian no, you cannot forward text to Mexican number
can't you receive the code in email?
if not, ask CS agent help
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
