03-11-2022 02:39 PM
I have 2 Add on US roaming 10 days on my account. How can I get rid of one?
Add-Ons
03-11-2022 08:58 PM
@doloresgwerder - are you sure you had both addons added successfully to your Plan Details area of your account?
If you only had the funds added to your Available Funds area then you really did not add the addons and your funds should still be there for future use for payment of services.
OR, it did glitch and you did successfully added two same type Roaming addons to your account....then yes, see @hTideGnow 's post.
03-11-2022 05:28 PM - edited 03-11-2022 07:41 PM
The content of the moved post was alraedy provided a few hours ago.
03-11-2022 03:56 PM
Cannot thank you enough for your reply. Just submitted a ticket. All the best, Dolores
03-11-2022 02:42 PM - edited 03-11-2022 02:42 PM
HI @doloresgwerder You purchased by twice by accident? Just open ticket with PM Support and see if they can refund or at least reverse the transaction and leave the fund to your account for future use
Click on the Bubble or directly at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
- Type "Wrong Add-on / plan purhcased"
- Then click "Contact Us"
- and then click "Click here to submit a ticket"
- you will then direct to another page to open ticket.
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
