08-01-2020 10:02 AM - edited 01-05-2022 12:37 PM
My one giga bit of date when I purchase as a add on it uses 95% of my data within hrs and it drives me nuts as I’ve turned off my cellular data for my apps as well why when I run out of my regular data I don’t recieve txt messagrs
08-01-2020 01:29 PM
@B_ride make sure your phone isn't syncing your photos and uploading it to the cloud over mobile data
08-01-2020 10:13 AM
Make sure to disable auto updates for apps and turn off GPS.
https://www.publicmobile.ca/en/bc/get-help/articles/managing-your-data-usage
08-01-2020 10:08 AM - edited 08-01-2020 10:09 AM
@B_ride wrote:My one giga bit of date when I purchase as a add on it uses 95% of my data within hrs and it drives me nuts as I’ve turned off my cellular data for my apps as well why when I run out of my regular data I don’t recieve txt messagrs
I'm guessing you're using an iPhone with iMessage. If you don't turn on SMS in it then you will use data if not connected to wifi.
As well as apps not updating, check that the OS won't update in cell data.
Edit: also check that you don't have the wifi failover to cell data option on.
