07-16-2020 02:03 PM - edited 01-05-2022 12:08 PM
for $15 plan, 100 mins Canada wide talk, how about 1800 toll free, is that count mins? thx
07-16-2020 05:43 PM
@Wholecloud correct. you can downgrade to $15 and purchase the $5 500min Canada wide. and add-ons keep rolling over until used up
07-16-2020 05:41 PM
I take it the airtime add-ons are the same price regardless of which plan you're on.
07-16-2020 05:26 PM
Thanks but I'm currently on the $25 plan so I need to figure out how much to see if it's worthwhile for me to downgrade as I done call out much.
07-16-2020 05:03 PM
@Wholecloud it's in the "plans add-ons " tab and then click my add-ons and all add-on packages will be there to purchase. purchasing an add-on requires 2 steps
- add funds to your account
- apply add-on
basically just pick the add-on hit apply and it will put "available funds" in your accoint
then go back choose the add-on and hit apply
07-16-2020 04:19 PM
I cannot seem to locate the add on fee for talk time if I go over the 100 mins for the $15 plan. Can somebody shed some light on this?
07-16-2020 02:10 PM
07-16-2020 02:08 PM
Most toll free numbers should not count towards your limited 100 outgoing minutes. Check your self serve account for any usage
07-16-2020 02:07 PM
@missorange wrote:for $15 plan, 100 mins Canada wide talk, how about 1800 toll free, is that count mins? thx
Officially yes. There are the odd reports of otherwise.
07-16-2020 02:07 PM
Hi @missorange,
If you are making an outgoing call, even to 1800, yes, it counts towards your minutes.
All incoming is free though (on the current $15 plan).
