Help
06-05-2020 07:20 PM - edited 01-05-2022 12:08 PM
No matter what i do i cant get my voicemail without having to dial direct...... Anyone know how to fix
Service
06-05-2020 08:05 PM
@jedjammer I always have to dial direct, thought thats how it was done LOL.
Or do you mean that you want to get your voicemail from a different device?
I just bookmarked my direct call to voicemail as "voicemail"
06-05-2020 08:04 PM
@jedjammer Go into your dialer settings and make sure the voicemail settings are correct.
06-05-2020 08:02 PM - edited 06-05-2020 08:05 PM
- try turning off your phone and removing your sim
- wait 5 min
- install sim and test
06-05-2020 07:52 PM
@jedjammer , what model of phone are you using? Perhaps try clearing the phone app cache and force close/restart the app.
06-05-2020 07:48 PM
@jedjammer use this list and find your local voicemail number
Save it under number 2 and use it to call your voicemail. Stay safe.
06-05-2020 07:34 PM
@jedjammer I've had this happen before after switching to a new sim card. In my case, it was a simple as restarting the phone.
06-05-2020 07:25 PM
Nothing
And in settings i try to set up but grey out.
06-05-2020 07:23 PM
@jedjammer what happens when you press and hold 1? Thanks. @Nezgar appreciate the help.
