11-17-2019 12:22 PM - edited 01-05-2022 09:45 AM
hello guys,
I am new to the network, how does $10 rewards work ?
I remember putting in the code from a friend reference at the time of sign up. but i think the funds were not applied.
please enlighten ..
thanks
11-27-2019 10:15 AM
Contact a moderator by clicking on?, bottom right, and following instructions. Another member also posted about this issue earlier. It's a common issue.
11-17-2019 04:55 PM
@Roohi wrote:hello guys,
please enlighten ..
thanks
@Roohi Check with your friend to see if they have received the $1 referral reward and text message. Take his code again. If it does not show up within 72 hours nor your friends click on the (?) At the bottom right of your screen and submit a ticket via simon. Ask for a human and fill out the form and submit. Have the referral code handy to give to the moderator.
11-17-2019 02:18 PM
Welcome to Public Mobile! I just joined this week as well.
My friend received a text pretty quickly after I used their code, and it took about two days to show up for me. I got a text from PM about the $10 credit, and now in my self-serve overview page, it shows the $10 as part of my available credit.
11-17-2019 01:17 PM
The reward should show up in your available funds within a few days.
11-17-2019 12:35 PM
When did you sign up?
You can check payment history, there should be $10 credit applied to your account within 3 days off opening account. Can you take a look in your history, if it's not there please contact moderators and provide your friend code again, they should be able to add it manually and fix your friends'account too. He should be getting $1 monthly as long as you stick around. You can reach moderators by clicking question sign and asking 'talk to human' until Simon lets you
11-17-2019 12:28 PM
@bros3n wrote:It will show up on your rewards screen in a few days, but will not be applied until your next payment. Your friend should also get a notification that they have successfully referred a friend, and their reward will show up also on their reward box on the main screen.
Works great!
@bros3n , for this reward it will go directly to available funds which can be seen on the overview page. It doesn't show up in the rewards section
11-17-2019 12:25 PM
please enlighten ..
thanks
I believe it takes up to 72 hours to show on your account. If your friends account shows your last 4 numbers as a referral......you will get the $10. Check your account to find it or they may text you when it arrives.
11-17-2019 12:25 PM
Works great!
11-17-2019 12:23 PM - edited 11-17-2019 12:24 PM
please enlighten ..
thanks
Generally overnight. Could be up to 3 days.
It's a credit that will appear in your Available Funds.
