Reply
Highlighted
Cannot Send Text Messages
I am new to public mobile and have a problem with sending SMS messages.  I have emailed the moderators and have received no reply.  I have no issue receiving them.  just sending them.  Please helo!!!!
Thank You
Accepted Solutions
Highlighted
Re: Cannot Send Text Messages
There may be a hour or two of delays after activation of your plan and number, I’ve had this issue also and has fixed itself with time do not worry it’s temporary. If the problem persists check to see if you have coverage in your location and if so then you should contact support!
All Replies
Highlighted
Thank You
Are sure its only SMS and not imesssage/MMS?
Highlighted
I cannot receive MMS or send MMS either
Highlighted
When did you port in?
Have you tried pulling out your battery and restarting the phone? New customers often have problems for some time after porting.
Highlighted
I can only receive sms   Cannot send or receive mms
Highlighted
You may have a partially completed port. When did you sign up?
Highlighted
Yesterday I ported in a number.
Highlighted
Is your data working?  If you do not have data in your plan you still need to make sure cellular data is turned on to send and receive MMS messages.  If you have data and are still having issues with MMS you probably need to update your APN settings.  Here is a great site for that http://apn-canada.gishan.net/
* I am happy to help, but I am not a MOD please do not include any personal info in a private message to me, click here to private message a Moderator *
Highlighted
Yes that makes sense as I just signed up.
Highlighted
You have already messaged the mods so they will be able to check into the port to see if there is an issue.
Locally you can continue to try to restart your phone
You can also try to configure your APN settings
There could also be SMSC set incorrectly.  I wish I had the SMSCentre number off the top of my head, but I don't.  Perhaps someone else knows it?
Does *#*#4636#*#* work on your phone?  If it does, it brings you to a Android hidden menu where you can manually change the SMSC.
