07-03-2019 05:50 PM - edited 01-05-2022 05:42 AM
HOW CAN ONE KNOW IF IT'S COMPATIBLE WITH PUBLIC MOBILE. MINE IS A HUAWEI K11
07-11-2019 08:59 PM
Thanks so much. That’s exactly my situation. Got it from Rogers 🙂
07-03-2019 07:17 PM
Rogers carried Huawei GR5 a few years ago. The box is showing Huawei KII-L05.
Did you purchased this Huawei phone from Rogers/Fido/Chatr?
If yes, it will work with PM.
https://www.frequencycheck.com/carrier-compatibility/5QEOu7/huawei-gr5-lte-kii-l05/telus-canada
07-03-2019 07:06 PM - edited 07-03-2019 07:07 PM
@WW29Quickest & Easiest way? Find a Telus / Koodo / Public Mobile SIM card that is already activated and just put it in the phone and test. If it works? Great.. if not you know your answer. Most cell phone stores already have a SIM card activated sitting there already.. just walk in and ask instead of going back and forth on the internet and wondering.
07-03-2019 06:14 PM
@WW29 wrote:HOW CAN ONE KNOW IF IT'S COMPATIBLE WITH PUBLIC MOBILE. MINE IS A HUAWEI K11
@WW29 that model is a bit tricky to locate. Was it sold in Canada? Or did you import it from China/Europe/India?
07-03-2019 06:03 PM
Yeah that service should really have a disclaimer that not all phones are listed.
You sure that's not KII and not K11? There might be another submodel variation somewhere too. You should be able to find all model numbers in the About phone menu area in the settings.
07-03-2019 06:01 PM - edited 07-03-2019 06:04 PM
good question! It's not listed on https://willmyphonework.net either 😞
The mods might be able to help you .. click @CS_Agent
DISREGARD my post, Alex's post is good 🙂
07-03-2019 06:01 PM
