System maintenance - From July 10, 2021, 23:00 ET to July 11, 2021, 10:00 ET
Silvio_M
Customer Support Agent
Hi Community,
Between July 10, 2021, 23:00 ET and July 11, 2021, 10:00 ET, you won't be able to do the following:
  • Access your Self-Serve account
  • Activate a new account
We apologize for any inconvenience this may cause.
** Please do not post private info such as phone number, account number, pin etc.. This is a public forum. **
7 REPLIES 7
@kylanicole wrote:
Does anyone know why Self Serve is currently down? No scheduled maintenance.. ?
If there's no announcement, I tend to think of the maintenance as unplanned.  I do notice that the these unannounced self serve downtimes tend to happen more often a night. Unfortunately, it seems as if the unannnounced maintenance periods are more frequent then the announced ones.  All I can say is to try again later. It'll likely be working again within a few hours. Some account activities can be perfomed by dialing *611.
kylanicole
Dtack
Thanks so much for the update - good to know this information so we don't panic!
adityanair23
Thanks for the update!
Lyang
Good to know, thanks
Staliger
Thank you for the info! It's good to be ready.
Usual monthly maintenance outage.  Thanks for the head up.
