Reply
Highlighted
Highlighted
Re: Call Control to block spammers for PM
@sahands , very unlikely.  Public Mobile is a tier 3 brand.  Only the most basic functions come to this tier.  The idea is to get customers who want more features to go to the higher tiers.
Highlighted
Likely not since Public Mobile is third tier. Telus 1st and Koodo second. Both offer call support. If you want cheap prices this is what you get I would think.
Highlighted
@sahands if you would like top tier features, lucky mobile has most of them and has "Universal Network-Level Call Blocking.
Highlighted
@sahands wrote:
https://www.telus.com/en/on/support/article/call-control-for-mobile-devices-explained
https://www.koodomobile.com/en/help/call-control?search_api_views_article_search_fulltext=call contr...
Will we get this?
Are you for real??? Look at what Telus offers..
Wow 25 blocked calls!!!
Just block all bad calls your self!!!
On an iPhone and maybe others you can control accepted calls based on your contact list BUT it may block the odd legit call that you have over looked putting into your contacts.
I would think I have a 100 or more on both my home line and mobile phone. And those are 2 different sets of blocked numbers.
The best way to control bad calls is to have an up to date contact list and be disciplined to block callers on your phone manually.
Every one wants a service because they "don't have the time" (<= which is bunk) vs making  an effort to control these annoying calls out of your life!!!
Once you get things in line you will be amazed at the lessened annoyances.
Highlighted
Every phone in Canada is protected by "Universal Network Level Call Blocking" - it is a mantatory requirement for all carriers in Canada, including Public Mobile.
However, what it blocks is very simple:
  • Caller ID of more or less than 10 digits (Long distance and country codes are not included in the count e.g. 1 800 111-1111 is considered a 10 digit number)
  • Invalid (e.g. area codes that do not exist or are unassigned, all 0’s, etc)
I know that this blocking is in effect at public mobile, because initially my outgoing call tests using voip.ms when I signed up would not go through to Public Mobile until I configured a valid (10 digits) phone number for outgoing caller ID.
Of course, this does nothing to stop spam calls that just forge valid 10-digit numbers...
Highlighted
Perhaps a search of how Telus call control works would help you to understand what a great feature it is. Zero robocalls while enabled!
Up-vote getting this feature enabled on Public mobile.
Highlighted
There are tooooooo many other things that should be “fixed” first before asking for an add.
Text to advise referred account has had suspension removed
Self serve option to change pin number
Self serve option to change email address
Have more than one account under one email address
etc etc
Highlighted
What I now do to deal with the spammers is never pick up my phone for unknown numbers or if I am not expecting a call (I hate talking on the phone anyway so don't even like picking up for known callers!). I have an outgoing message on my voicemail that says I do not check voicemail and to try calling back (in which case I usually pick up if I get a second ring from the same # the same day) or text/email me instead (everyone that would call me has my email or can text me). I have my voicemail box closed so no one can leave messages. I have found this greatly reduced the # of spam calls I get since they never get an answer and I never have to go into my voicemail to delete spam recordings...
Highlighted
My contact list is very up to date and any call with a number only means they are NOT a known person so I would be hesitant to answer.  Keep in mind blocked callers will go direct to voicemail.
