What are the easiest ways to enable lock screen weather on Android phones?
devkum1234
What's the best app to show weather on my lock screen? I have an Android phone and I want to see the weather right when I unlock it. What apps do you guys use?
12 REPLIES 12
@ORNGNBLK  FYI this will undoubtedly be moved to the “lounge” as it’s not support relate
Not to mention that @devkum1234  has posted this or similar questions on more than one occasion in the past, which also got moved to The Lounge.  Not sure what the purpose of these posts is.
ORNGNBLK
@devkum1234 FYI this will undoubtedly be moved to the “lounge” as it’s not support related or Public Mobile specific. For future reference.
devkum1234
I was just wondering, how do you think using the best lock screen widgets can make Android better? Like, do they actually save time or make life easier? I'm looking for ideas or suggestions about cool widgets that really improve the experience. Share your favorites or tips!
Shubh2023
Are you on Android 14/15? and depending on your device, you should have customizations!
Motorola has a lot of customization options, or Pixel does too
devkum1234
What are the coolest lock screen widgets for Android? I want to make my phone look awesome and show important info like weather, time, and maybe even my calendar. Any suggestions?
@devkum1234   Assuming you now have the app that you were looking for in a previous question and it offers a widget, something like WeatherCan from Environment Canada for example, on my Android you just long press somewhere on the home screen and then the option to customize with widgets etc. appears.
ORNGNBLK
What device are you using, some have the capability, some don’t. Let us know what phone model you have and I’m sure someone can find a solution.
devkum1234
I'm new to Android and I can't figure out how to add a weather widget to my lock screen. Someone, please help!
cameronwhite
Hey everyone, quick question, Is the Glance widget available for Android? I’ve seen it mentioned a few times, but I’m not sure if it’s supported on android devices or how to enable it.
cameronwhite
I’m exploring ways to get the most out of my Android phone, and I’m curious about the lock screen. It’s more than just a way to secure the phone, right? What are some unique or lesser-known features that can make my lock screen more functional or fun?
@devkum1234
I use the weather widget on my Samsung S24. It works for me.
