08-15-2022 07:36 PM
@MrSpock- I would disagree here. The OP said they bought data. That shouldn't be a problem.
08-15-2022 08:04 PM
@MrSpock- No problem. Although you're speaking in the singular twice now. It would be my opinion that only the talk add-ons are the problem and for the obvious reasons. The text add-ons and the data add-ons SHOULD theoretically be fine on either partner.
08-15-2022 08:00 PM
@dust2dust Like I said I don’t mean to argue with you it’s just my opinion the add on sucks
08-15-2022 07:56 PM
@MrSpock- Maybe the OP could report back which provider sim they got. Sounds like they've had a lousy experience with T-Mobile where they are so maybe they got AT&T or a related MVNO. They didn't report back with any success of the idea of switching to AT&T with the add-on. I suspect that's all moot now as they have this other service. Also, swapping sims could reset things and clean up problems. I'm not ready to denounce Public over roaming data connectivity just yet.
Talk??...that's not the fault of Public. Maybe they simply shouldn't be selling talk.
08-15-2022 07:50 PM
@dust2dust I am not meaning to be argumentative but their sim they had to buy works for data so what’s wrong with public add on ? There are way to many problems with their U S add on
08-15-2022 07:44 PM
@MrSpock- Have you read my many negative comments towards the company? I am most definitely not defending them. The talk add-on is the problematic one for all the reasons we all know. The data (and text) should work just fine on either partner. I suspect this is a reception/area problem.
08-15-2022 07:38 PM
@dust2dust Well it doesn’t seem to be working on three phones and they had to buy a sim so defend public all you want, in my opinion their roaming add on sucks
