09-12-2024
01:10 PM
- last edited
Tuesday
computergeek541
I'm trying to make my Motorola lock screen look cooler with those widget things you know like showing weather or steps or whatever. But I'm kind of confuse and lost on how to do it. Can someone explain it easy ? Like step by step and and i heard something about Glance what's that about
3 weeks ago
One more thing why I can't see my question I just posted on my profile did you removed it...?
3 weeks ago
Ok thanks buddy for your support and understand
3 weeks ago - last edited 3 weeks ago
no rule breaking, I just feel bad seeing you posting the same question month after month
for questions like that, you will get better answer elsewhere
And the best lock screen widget is always the one provided by the phone itself, it uses less resources and you shouldn't need too much info on the lock screen anyway, why waste time installing extra
3 weeks ago
Sorry but this time I'm not asking this for myself this is question I'm asking on behalf of my friend sorry if I'm breaking any rule of forum
3 weeks ago
is this a real question or just spam?
you posted this from Sept to now, keep posting
you said you have a Moto phone and the RealMe. If you still have not got the answer here, why not post in another phone forum for better support?
3 weeks ago
What are the best lock screen widgets out there I need something that’s useful and not just fancy I want quick access to info like weather updates calendar events or even news without unlocking my phone Are there any widgets that learn my habits and show what I need before I even search for it Also how do they handle battery life I don’t want something that drains it too fast Any recommendations for widgets that are easy to set up and customize I’m curious about ones that offer live updates and interactive features without being too cluttered What do you use and why
09-17-2024 08:40 PM
Try long-pressing in the empty area of the screen. Every Android phone is slightly different but the long press should reveal additional menu options. One of them should say “widgets”.
that said, you do need to have an app that also provides a widget. Maybe your weather app doesn’t have that option. I’m also not sure if there is anything like step counter in a widget. That said, I’m sure your phone has some helpful widgets available. Let us know if you need any additional help!
09-15-2024 06:50 AM
I have edge 50
09-12-2024 02:15 PM
Sorry, I do not have a Motorola phone. Which model phone do you have
You might want to go to Motorola website and see what is suggested there.
