Unable to complete set up: stuck at Adding old account info
jdumbrille
Its been an hour now, so Im close to sending my sim card back for refund. The idea is I should be able to activate it. I have added the old account name, my alt contact number, and the correct serial number for my iphone. Note that the order of adding info is counterintuitive - you need to addd the serial number last, even though it is high up on the form. Failure to do so clears the info when the alt no. is added. Even working around this, selecting "Continue" results in the form emptying and "Processing" is shown on the screen. There is no result, and no visual cue to why no result. This is very frustrating. Has anyone had a similar issue? What is the work around?
19 REPLIES 19
@gpixel wrote:
@geopublicthe OP's employer would not release the account number.
@gpixel  If the number is part of a business account then the port will fail unless the employer allows the number to be converted to a Bell personal account.
@jdumbrille wrote:
Ok thanks - the public mobile form indicates you can use the serial number instead. This is what my employer has said too -  I dont need their account number
@jdumbrille  Using the Bell account number instead of IMEI is the safest way to setup a port. Your choice.
@jdumbrille
  1. You get the imei number by dialing *#06# not *#60#. As you keep doing.
  2. I don't think you need it to  port.
jdumbrille
doh thanks
@jdumbrille you have it backwards... it's 06 not 60
jdumbrille
Adding the asterisk to get *#60# has the same result
@jdumbrille   *#06#.
jdumbrille
jdumbrille
phoning #60# results in an error - Error performing request unknown error
I believe Ive followed the protocols listed and the serial number is clearly marked on the iphone, and Ive copied it correctly
@jdumbrille  You should be able to port with the name on the account,  phone number to port and the old providers account number from Bell.
Barbie2
@jdumbrille I wouldn't add the serial number it is not needed. Just the name and phone number and account number from Bell you are leaving.
1. name
2. account number
Im not an expert but I do think this will be helpful. ❤️
jdumbrille
the Service provider is Bell
@jdumbrille try the imei numbrer. Dial*#06# to get it. Heres an article on activating and porting
1.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
2.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
jdumbrille
Thanks gblackma
Are you saying the sim card needs to be added before activation?
@jdumbrille who is the service provider you are transferring from?
jdumbrille
Note: the message is "You must enter at least one value to proceed."  The value does not appear have been recognized - as it is cleared after entering and pressing Continue - but it is a valid (Serial) number.
gpixel
@jdumbrille I never ran into this issue when I activated my account. use your browser in incognito private mode.
gblackma
@jdumbrille clear your browser history,  go to private/ incognito mode and try again to activate  your SIM card. If the proble persists activate with a temporary number and contact the moderators to port your number after. If you are trying to port from Koodo prepaid or PC mobile rhis is the process. Welcome to PM.  Stay safe.
