06-23-2020 03:59 PM - edited 01-05-2022 11:49 AM
I bought a new phone. The sim card insert was different so I purchased a new one. My problem is even though I already have my account it wants me to create a new account to put a new SIM card... can anyone help with this
06-23-2020 04:45 PM
SIM Card Change succesful
06-23-2020 04:37 PM - edited 06-23-2020 04:39 PM
@Baz71 wrote:Thank you all for your help.. fingers crossed
If you have not changed your SIM card to the new one, you may use your current SIM card.
If you need a small sSIM card for the new phone, examine your current SIM card to look for the adapter cut line. Remove the adapter if you find it. That is all you need to do. Refer to the picture on @geopublic's post for details.
Save the new SIM card for your referral.
06-23-2020 04:36 PM
Please don't use the new sim, keep it if you need it later
You can punch out the old SIM into smaller card
Or if you need it bigger, you can use plastic parts of the new sim for your older sim
06-23-2020 04:10 PM
06-23-2020 04:10 PM - edited 06-23-2020 04:18 PM
@Baz71 wrote:I bought a new phone. The sim card insert was different so I purchased a new one. My problem is even though I already have my account it wants me to create a new account to put a new SIM card... can anyone help with this
@Baz71 No need for a new card. All PM cards are tri-punch.
Just select the correct size by punching out or adding the spacer. Keep the other card as backup. You can also switch cards, no need to activate the new card, simply by going into selfserve and selecting the change sim card option.
06-23-2020 04:02 PM - edited 06-23-2020 04:03 PM
06-23-2020 04:00 PM
