Reply
Setting up voicemail
Does setting up your voice use any of the minutes on your plan?
Re: Setting up voicemail
Yes it does.
https://www.publicmobile.ca/en/qc/get-help/articles/set-up-voicemail
After your initial setup, there is no charge to check your voicemail from another phone. You can call the voicemail number (like xxx-580-4001) from another phone, then enter your phone number and pin.
