Reply
sp00ny780
Merge Accounts
Is it possible to merge multiple accounts into one login/account? I know I'd lose the refferals, but I'm leaning towards convenience because all four of our lines have different dates.
Accepted Solutions
Re: Merge Accounts
Hi @sp00ny780 ,
You can use alias emails, which would allow all correspondence be sent to one location (email) for as many alias' you want set up/connected. Google how to use alias emails by whichever source you use, gmail, outlook, etc.
You would not lose Rewards (Loyalty, Refer a Friend or Autopay) if you change your email connected to your SELF SERVE account. In order to change your email that is set up for your SELF SERVE, you need to ask the Moderators to do this.
Community Rewards are connected to your SELF SERVE email and the corresponding Community Account/email. So, if you change your email to a SELF SERVE account (through MODS), you can always change the email connected to your Community Account yourself under you Avatar (top, right corner), then under "My Settings".
All Replies
Quigley
Re: Merge Accounts
No sorry, that's not possible or allowed here. Every phone number needs it's own account and email address. You can use the same CC for all the accounts though.
Re: Merge Accounts
Hi @sp00ny780 ,
will13am
Re: Merge Accounts
@sp00ny780 , I suggest using auto pay if you are not already doing so.  You save $2 per renewal and don't have to worry about manual payment.  Having different renewal dates on each account is perfect for using a single payment card.  Multiple payments to the same vendor at the same time can trigger anti fraud protection and lock down the credit card.
HALIMACS
Re: Merge Accounts
It's a great question, @sp00ny780
The functionality of the self-serve site with the account pull-down menu option might suggest that option exists (or once existed...):
However, alas, it does not, leaving one to wonder why the web page is designed with such a pull-down feature built in.
At the end of the day, it has to do with the Community association with the User account being associated by e-mail address coupled with the User account defaulting to one's e-mail address.   Perhaps with the reward system employed at Public Mobile, it was challenging to merge customer accounts into ONE login and maintain their business model around reward systems.
