Conference Call Feature not working
Harry
conference call feature was to be included with the unlimited Canada wide calling option.
9 REPLIES 9
Mary_M
Retraité / Retired
Retraité / Retired
awesome @Harry, thank you for letting us know 🙂
Cheers,
Mary
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
Harry
Thanks for all the help. The feature is now working.
Mary_M
Retraité / Retired
Retraité / Retired
Hey @Harry,
thank you for reaching out to us !
I can see that my colleague replied to your private message on October 6th 2017. If you still need any help with your conference calling, feel free to shoot us a message 🙂
Respectfully,
Mary
henrik
Hi Harry,
Are you still having issue with conference calling?  You can also check if Call waiting is working?
If so, you should PM the @CS_Agent with your phone number to check if your profile is created properly.
as noted by the user, conference calling is actually just a 3 way calling.  It can't go beyond 3 callers in the same line.
Hope this helps.
jackfzhao
mine is working fine, but conference call can be made within 3 people
MVP
So, is conference call feature working now?
Incidentally I need to use it  soon, and would love to make sure it works
srlawren
@Harry, like @will13am, I've yet to use it either, but it's definitely supposed to be included, as you pointed out.  You may want to take a moment to send the moderator team a private message using this link and ask them to check your account.  It's possible there may be a glitch that's prevenitng you from using it, but hopefully they can take care of it quickly.
Harry
Unfortunately I tried that solution. The message I get is that the feature has not been activated.
will13am
I haven't used the feature myself.  I suggest checking this link out to make sure the feature is being used correctly.
https://productioncommunity.publicmobile.ca/t5/Discussions/Standard-calling-features-in-the-plans/td...
