annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
How can we remove the 'long distance charges may apply" message?
jacinthe007
This is very annoying and I would like to know if it is possible to remove it.
1 SOLUTION APPROUVÉE
Solutions approuvées
This means that the call is long distance. The message usually isn't a mistake, even though long ditsance to all Canadian phone numbers is included with all currently offered price plans. To avoid hearing the message, dial a 1 before the area code.
1 RÉPONSE 1
