05-10-2019 10:27 AM - edited 01-05-2022 04:51 AM
05-10-2019 11:29 AM
@Jmancia18 Maybe an oracle might consider merging your three threads so that everybody can get a better understanding of all the issues you are experiencing (Plan, Account access)
05-10-2019 11:25 AM
But not I haven’t changed the plan at all
05-10-2019 11:24 AM
I can’t even tell because every time I go on my account it gives me no information all it says is “hello” on the page
05-10-2019 10:47 AM
@Jmancia18 wrote:How can I change my plan then
Logging into "My Account" (Self-Serve) you are able to click the "Change Plan" button (Located in the first box under "Account Status"). Please note though if you change plans right now, you will lose anything you have already paid and get billed again. You are better of scheduling the change for your next renewal (unless you have burned through your limited plan already).
05-10-2019 10:46 AM
@Jmancia18, have you changed a plan, and had it charge immediately? If yes, this is why you think you've been double charged.
There are two options when changing a plan, you must have selected the immediate option. The other option is to choose "on next renewal". This would allow your plan to continue until your next payment, which is when the payment would be charged.
05-10-2019 10:45 AM
Login to your self serve account. On the overiew page, there is a change plan button. Select the plan you want to change to, then decide if you want the change to happen immediately or on next renewal. Note that immediate plan changes will result in the current paid cycle being lost with no refunds.
05-10-2019 10:37 AM
05-10-2019 10:29 AM - edited 05-10-2019 10:30 AM
@Jmancia18 wrote:How do you cancel and get a refund on your account
There are no refunds...you can run your service out then just remove credit card info. After 90 days your account is closed for good.
