Reply
Data not working
I recently switched my phone and my data hasn't been working. I still have over a GB left and the data is turned on in my settings. I have also tried a power cycle. No luck. Any solutions.
Re: Data not working
Android or Iphone?
Did you try cycling Airplane mode? Cell Data?
Have you checked APN Settings?
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Tried restarting the device ?
Im not sure what apn settings are?
Several times
Android or iphone, @Reneelynn12 ?
Android
Andriod
Are you changing to a LG phone?
After changing provider, you need to do network reset on LG phone before your data working again.  Make sure to restart your phone after network reset.
If the APN is not setup correctly after phone restart, you need to setup APN manually as above.
Settings -> (might need More here) ->Mobile or Cellular Networks -> Access Point Names
Yours should say Mobile Internet - sp.mb.com.
Click on that and compre it to this:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
