Calls/texts working but no data - can't connect to network
Grapefruit11
Hi, I bought a SIM card and activated it online. Got a text saying my port from Virgin was successful and calls/texts work fine. However, data doesn't work. In the settings, my IP address is listed as "unavailable" and mobile network state is either "connecting" or "disconnected". I've tried popping the SIM card out and back in and rebooting but that doesn't do anything. Phone is Asus Zenfone 3 on Android 7.1.1. Any help would be greatly appreciated! 1543721535221__01.jpg
12 REPLIES 12
ChuckYeah
@adronis best to start your own thread. It may get lost in this one from 2018.
adronis
This did not work on my zen phone 3
Grapefruit11
@wetcoaster wrote:
The next thing I can think of would be a network reset. Not sure if that helps with your phone (LG phones are notorious for needing one when switching carriers) but worth a try. It's less invasive than a factory reset.
It works! I did a network reset and rebooted and I was able to get in and add the new APN as per RobertQc.
Thanks everyone!
@Grapefruit11 wrote:
I can't seem to get into the access point settings. When I try, it just reloads the same page. Not sure how I can get to the settings?
RobertQc's post above had detailed steps. Those didn't work for you? Are you in fact on Android 8.1?
Edit: And you have data in your plan? And your cell data mode is on?
Definitely 7.1.1. Have 5gb data on my plan and data is enabled. Asus Z01BDC, which I believe is the Zenfone 3.
RobertQc's instructions were detailed for sure but when I touch "Access point names" it won't let me access it. It loads to that page for a fraction of a second then goes back to the previous menu. I caught "APN" as the page name but it won't stay.
Do you have an option to add a new APN and then delete the old one?
Grapefruit11
popping
What phone are you using?
Grapefruit11
Grapefruit11
I disconnected WiFi after taking the screenshot. WiFi works fine but when disabled, data doesn't work.
will13am
@Grapefruit11, WiFi takes precedence over mobile data.  You are connected to WiFi and so mobile data is disconnected.  What happens if you disconnect WiFi?
RobertQc
@Grapefruit11
The most likely cause is the APN. You need to configure your APN settings to be able to send pictures (MMS) and navigate on internet (DATA). Your "Mobile Data" needs to be activated.
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Name: Public Mobile / Mobile Internet
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Select Save/Done. Select Public Mobile to connect to the Public Mobile network.
APN Tethering Settings:
Name: Tethered Mobile Internet
APN: isp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 220
Authentication type: Not set
APN type: dun
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
