wrong add on
scapper1
I think I bought wrong add on can it it be changed or refunded
7 REPLIES 7
chukdefatey
@scapper1 wrote:
Yah gotta get some cash and do that does it restart cycle when you change plan
You could sechedule your plan change at your renewal time.
scapper1
@scapper1 wrote:
I am on 10 dollar plan I was wanting to add on texting , so I got the us roaming-international text I see now that is only for use in the usa no plans to go there don't have passport did not see it on overview
Unfortunately there's no texting add-on.  Considering getting the $15 plan which offers unlimited texting.
scapper1
will13am
@scapper1, by terms and conditions there are no refunds.  However, the moderators are reasonable with applying goodwill for situations like this.  I suggest you purchase the add-on that you need and seek refund for the one that you purchased in error.
Which plan are you on?
Which add-on did you get?
Which add-on did you want?
Do you still see the amount you paid in your Available Funds?
Do you see the add-on lower down on your overview page?
ChuckYeah
As a rule, there are no refunds on prepaid accounts at PM.
You could ask by contacting a moderator.
Contact @Moderator_Team
It can take up to 48 hours for the team to respond to your concerns.
