why do websites not load while using public mobile
Kfar
Over the past few months I can no longer access websites while using public mobile. Any idea why?
Kfar
Thanks! I Reset the Network Settings and it works now!
@Kfar on iPhone, you cannot update the APN
First, make sure you have latest iOS, then update Carrier Settings and  Reset Network Settings
if that does not help and if you have another phone, test the SIM on another phone
Kfar
Thanks. I am using an iPhone SE. I could access data up until a few months ago, but not anymore.
@Kfar
what phone do you have? it is an APN issue.  Start with Reset Network Settings on your phone
if that does not work, update the APN settings
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D      (or try:   4D4F)
