09-24-2019 06:27 PM - edited 01-05-2022 07:16 AM
I have made two phone calls local and received and sent about ten messages. thats it.
msg on face of phone when i try to call someone: emergerncy calls only. whats up with that?
09-25-2019 12:39 AM
09-24-2019 07:51 PM
What is your status when you login to self serve?
09-24-2019 06:35 PM
Try rebooting the phone or Shutting off the phone and taking the sim out for 10 minutes, reinstall it and turn the phone back on. Anything happen just prior to receiving this message?
09-24-2019 06:33 PM - edited 09-24-2019 06:34 PM
@88Swap your SIM card to another phone.. see if it is a phone problem or a Public Mobile issue. It could be your SIM card is not contacting correctly.. or your phone has been blacklisted if you got the phone second hand.
@hairbag1If the OP is out of minutes, it will still have service and won't default to Emergency Calls only.
09-24-2019 06:30 PM - edited 09-24-2019 06:32 PM
Are you on the $10 plan ? If so, you've likely run outta talk minutes. Get the $5 for 500 minute add-on. You'd be able to call anywhere in Canada (while you're in Canada) for 500minutes and it rolls over until you use it up.
