07-13-2022 07:19 AM
07-13-2022 12:14 PM
If you're like me and still seeing the login issue, this is what I found that worked:
This is to access the new version of My Account.
Option #1 doesn't seem to work to access the My Rewards website though. That might require some fix on Public Mobile's side.
07-13-2022 08:40 AM
It just worked now for me to purchase US roaming addons
07-13-2022 08:40 AM
Thankfully it now seems to be working
07-13-2022 08:31 AM
The add-ons feature is still not working it says looks like the page you're looking for is unavailable error 404
07-13-2022 08:24 AM
07-13-2022 08:20 AM
@softech yes, I'm leaving for the states this morning and wanted to add some data on my plan for navigation. I'll keep trying, but I'm still not having luck.
07-13-2022 08:19 AM
How soon do you think the maintenance will be completed? I was looking to purchase add-ons today
07-13-2022 08:15 AM
07-13-2022 08:13 AM - edited 07-13-2022 08:17 AM
@Kasstzog wrote:Also having this issue since last night. Was there an announcement about maintenance?
@Kasstzog No, this is not a scheduled maintenance.
@gglobrien Not because of popup blocker.
07-13-2022 08:13 AM
yes mine is done too. does popup blocker affect this?
07-13-2022 08:07 AM - edited 07-13-2022 08:10 AM
07-13-2022 08:07 AM
@Del1981 You are in a rush to do something? Maybe try *611, but you need your 4 digits code for most thing you want to do there
07-13-2022 07:34 AM - edited 07-13-2022 07:34 AM
@Del1981 wrote:Any experience in knowing how long maintenance usually takes?
Please try again in about 30 minutes (after 8am EDT - eastern).
07-13-2022 07:33 AM
07-13-2022 07:32 AM
Same here, can't log in. There's a different log in window now, and I get the same message when I attempt.
07-13-2022 07:30 AM
07-13-2022 07:24 AM
did you get this error:
{"message":"Invalid authentication credentials"}
I guess maintenance again...
