6 hours ago
- last edited
2 hours ago
computergeek541
Can I make whatsapp calls if I have a plan with 20 gigs? Can I make them even from a Wi-Fi network?
5 hours ago
6 hours ago
Yes you can make calls on WhatsApp on wifi or your data. Wifi would be your cheapest option.
6 hours ago
yes, as long as the Whatsapp is registered with the phone number, you can use it on Wifi and mobile data.
