11-27-2019 09:27 PM - edited 01-05-2022 09:50 AM
11-27-2019 09:57 PM
Thanks for your help guys! I got the 500 min add on. Everything back to normal ![]()
11-27-2019 09:35 PM - edited 11-27-2019 09:36 PM
@car23888 wrote:thanks for asking, my phone has been set up for a couple months now. just today though I am unable to access my voicemail. whenever i dial my own number or the VM number the call is rejected as being long distance and public mobile mssg says I need to buy a long distance add on. Any help is appreciated. Even when I edit the numbers they revert back to 1+ format.This not an issue until today. I have an android deviceThank you
What plan are you on?
if it's the $15/100 outgoing minutes you might have depleted your minutes. If you log into self serve and the minutes xx/100 does not show on the overview page, you have used them all. Buy the $5/500minutes add-on to tide you over until renewal, all unused minutes of the add-on will carry over until you need them again, they are yours until used up, whereas your plan minutes will reset on renewal day..
11-27-2019 09:31 PM
Which plan are you on? Are you able to call other numbers?
If you are on the $10 or $15 plan, is it possilbe that you ran out of minutes?
11-27-2019 09:29 PM
Have you tried holding down the number '1' to reach your voicemail?
Do you have any minutes left on your plan? Calling voicemail deducts from plan minutes.
