voice
05-05-2023
03:00 PM
05-05-2023
04:18 PM
computergeek541
05-06-2023 09:35 AM
@dust2dust wrote:So when you find some time then go in to the voicemail system and tap 3 then 4 then 2. Record a greeting. After that maybe having to go back to that same menu spot tap 4 to turn it on. After that maybe having to go back to that same menu spot tap 5 to disallow anybody leaving a message.
The phone will ring. You'll see the missed call if you ignore it or miss it. Then that caller won't be able to leave a message and you won't get any voicemail notification.
I suspect the problem you've recently found is that conditional call forwarding has become broken likely in relation to volte. Apparently support can fix this.
Wouldn't it be a whole lot simpler , faster and cheaper for all those involved if a trained CSR took 30 seconds and just turned it off ..
05-05-2023 03:45 PM
Ok thanks ...I will see what I can make work ... aren't they supposed to improve things as time passes ?🙄
05-05-2023 03:32 PM
@barndoor so, you used trick to "disable" not allow people to leave VM?? Conditional forwarding was broken since the enabling of VoLTE. I don't think it is fixed yet. You might have to use the Extended leave message to "disable" VM
05-05-2023 03:30 PM
05-05-2023 03:16 PM
Yes Softech I know you are a customer like me but I thought I had already posted my question ..twenty minutes ago ...but I apparently I didn't and I don't have time to be playing around trying to sort out phone issues right now. thanks for any help .
05-05-2023 03:08 PM
new My Community since around a year ago. You will need to pick a label to post
05-05-2023 03:08 PM
For two years now I have been happy as a clam with no voicemail ... now today I gt a beep and it says I have voicemail again . Do I have to redirect it every so often . I tried one number to make it go away but it didn't work .
05-05-2023 03:03 PM
@barndoor yes, you posted. We are customers like you but would like to help
What is your voicemail question???
05-05-2023 03:02 PM
I've been away to long I guess ... why is it such a challenge to post here ?
