06-12-2020 04:52 PM - edited 01-05-2022 11:40 AM
09-21-2021 09:41 PM
@ELMULL : What plan are you on? If the $15 plan then perhaps you're out of minutes. Checking voicemail here uses minutes as it's like a phone call. You can use another phone to access your voicemail.
09-21-2021 08:15 PM
I cannot get into my voice mail I put my password in it goes to voice mail then cuts out within a second
06-20-2020 08:45 AM
You can also set it up to go right to voicemail no password needed
06-13-2020 05:10 AM
06-13-2020 03:13 AM
Press and hold 1 on your dail pad.
06-12-2020 05:11 PM
Thanks!
06-12-2020 05:10 PM
Oh great - thanks so very much - I now have that set up! Much appreciated!
06-12-2020 05:05 PM - edited 06-12-2020 05:09 PM
@Dtack open your dialer app and hold 1, it should send you to your voicemail
06-12-2020 05:02 PM
Welcome to PM @Dtack here's an article on setting up your voicemail
https://www.publicmobile.ca/en/on/get-help/articles/set-up-voicemail. Stay safe.
06-12-2020 04:58 PM
Thank you!
06-12-2020 04:56 PM - edited 06-12-2020 04:57 PM
You should have an option on your phone to go into settings and then search for voice mail. It will show your provider and your voice mail number. You can also set a sound when you get a voicemail for a notification.
edit: call that number and it will prompt you to input a password and recording etc. 🙂
Welcome to Public Mobile. So glad to have you here stick around and give some input for extra rewards! 🙂
