12-20-2022 11:10 PM
I want to change my username and password for community sign-in. When I follow the instructions on the community sign in option, the link and email only allows me to change password, not username? Thanks for help in advance.
Community
12-20-2022 11:18 PM
@acheung Open ticket with PM support and they can help to change username used for Community
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
12-20-2022 11:13 PM
You could abandon this one. Change the email address on it to some junk fake one. Make a new one and use the email address that is registered on your account.
Otherwise only support can change the username.
