us add on
12-30-2019 03:07 PM - edited 01-05-2022 08:47 AM
My plan is showing 200 us roaming data.....byt my phone shut on as soon as I crossed the border
Joining Public
12-30-2019 04:03 PM
@hairbag1 edited my post to add link for two step guide to purchase add-on which I had to search for. May have added one more line but my original post before additions did answer opps question of 200 min..and I provided pic of different add-ons..
But Thanks Chief for your insight👍👍
12-30-2019 04:00 PM - edited 12-30-2019 04:00 PM
@hairbag1 wrote:
@Jb456 wrote:There is no such plan. If you're talking about 200 us and Canada long distance add-on. That is only when you're in Canada.. you have to buy a USA roaming add-on
Two steps to buy an add-on.
Guide on below link.
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/td-p/198974
@Jb456...I think you're fairly new here so here's a pointer on proper etiquette. It's kinda frowned upon when you quickly add a comment just to be first in line...then later on, make additions to your original post using info you've gathered by others.
Do what you like, but that's my opinion.
The worse one is where someone replies real fast with a blank and then fills it in after.
I've only seen it on one or two occassions. I call it the placeholder.
My approach to this is to add more prefaced by "Edit:". But that's me and my opinion.
12-30-2019 03:55 PM
12-30-2019 03:40 PM
I believe it was 2 gigs of USA data that was offered with $60 plan
12-30-2019 03:29 PM
If you have the grandfathered $60 plan with 200MB US roaming data, after you arrive at your destination, enable data and roaming and restart your phone. You will be connected to the AT&T or T-Mobile network.
If you purchased a data US roaming add-on, do the same procedure to get data working.
12-30-2019 03:25 PM
@gsfraser52 wrote:My plan is showing 200 us roaming data.....byt my phone shut on as soon as I crossed the border
200MB data add-on only works in Canada. Do you mean 250MB?
12-30-2019 03:10 PM - edited 12-30-2019 03:12 PM
Those 200 minutes only work while you're in Canada calling to US.
You need the 10 Day US Roaming talk/text/data add-on options available.
12-30-2019 03:10 PM
You do need to turn on data roaming on most phones.
You can manually choose either AT&T or T mobile.
