unregistered
Finesse
My friend has just activated his mobile phone number, but the phone card shows that he has not registered on the Internet. What is the reason?
srlawren
@Finesse did you mean it says it's not registered on the network?  If so: what is the device's make and model?  Did your friend previously use the phone with Rogers/Fido/Chatr and could it have come from outside of Canada originally?
SethPenner
Do you mean that texts and phone calls work, but they aren't able to use their data? If so, I had the same issue when I first registered for Public Mobile. I contacted a Mod and they quickly resolved the issue!
HALIMACS
@Finesse
Do you possibly mean your friend hasn't registered for a self- serve account?
If so, they can do do here:
Public Mobile - Register
Phone calls and text messaging work?  I think that this is likely to be an issue with the APN settings on the phone. I would suggest taking a look at this site:  Set up data on an Android phone (publicmobile.ca)
From that link, the settings of are shown:
"Name: Public Mobile
  APN: sp.mb.com
 MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220"
You may also need to set the APN type to default,mms on some Android devices (if you're using one).
