unlock 2 phones
Mike30
i have 2 identical bell phones. I unlocked 1 using a public mobile sim. can I unlock a second phone using the same sim and unlock code? or will I have issues.
thx
mike
Naepalm
@Mike30 unlock code is for each undividual phone. But if you wanted to.you can use the sim in both phones. But you would.pnly.have 1 account then? Is there a reason you want to.use 1 SIM in two phones?
Go to MYBell and request the phones both to be unlocked. they will send you an email with an unlock code if they are older than 2017. If they are newer then 2017 they dont.need to.be unlocked.
Also unlocking your phone is free.
popping
@Mike30
Unlock code are different for each phone.  Each phone has 10 tries.  Don't waste a try if you know the code is not for your phone.  Phone Bell to get the correct code for your phone by supplying the IMEI # of the phone your want to unlock.  To get the IMEI #, dial *#06#
DOA
thx
mike
You'll have to get another unlock code from Bell, but you will be able to use the same PM SIM to unlock the second phone.
geopublic
@Mike30  No, each unlock code depends on the phone's IMEI. You need too call and get a different unlock code for the second device.
gblackma
@Mike30I don't know. Can't you contact Bell and ask them for the unlock code? Welcome to the community.  Stay safe.
iliketotalk
@Mike30 Hi no you will need to contact bell to get the unlock code for the second phone because they have different IMIE numbers, but you can use the same sim in both phones at different times if you like also if they are samsung you can contact them online and their online support will do a master unlock for you
