unknown outgoing calls
map47
HI,
I Have seen a couple of outgoing calls on my bill that i did not make how can i have this situation addressed? i just signed in with PM in March! thanks
map47
HI,Thanks for the reply i hope you are right,regards
Sansan
Whenever you check your voicemail or someone leaves you a message,  it registers voice mail number. The number usually ends in 4001, 4000,-7.
hairbag1
@map47
they are most likely voice mail numbers.
