04-14-2019 03:37 PM - edited 01-05-2022 04:22 AM
new here and cant figure out how to contact a moderator
11-13-2019 01:43 PM
I'm trying to get back my account
04-15-2019 04:47 PM
@slash407 wrote:just click new message and then type mods and a list would popp up
This is wrong. Only "Moderator_Team" will work.
04-14-2019 09:18 PM
Thank you so much, Have a good night
04-14-2019 09:03 PM
@sameh wrote:I sent a message to them more than one hour but no reply.
I activated a tmprorarynumber as the activation process asked me for that
The moderators are working through a queue of messages; if you haven't heard back yet, it's because they are helping other subscribers. They will eventually be in contact with you.
Moderator hours:
Weekdays 8am to 12am
Weekends 8am to 10pm (eastern time)
04-14-2019 08:56 PM
04-14-2019 08:52 PM
Scroll up a few posts...NDESAI..posted a link to contact a moderator...
04-14-2019 08:50 PM
Hi, Did you get help from the moderator?
I have the same issue as you
04-14-2019 06:20 PM
@joshuanielsen33 wrote:thanks not used to doing things this way.
Tip: After contacting the mod, while waiting for the port to complete keep using your Koodo SIM card to make/receive calls. Once your phone stops working it means that the port is 100% complete then switch to Public Mobile SIM and all should be good to go.
04-14-2019 05:12 PM
04-14-2019 05:08 PM
@joshuanielsen33 You will need to send a private message to the Moderator_Team and they will get in touch with you shortly.
04-14-2019
05:07 PM
04-14-2019
11:26 PM
computergeek541
been on here all day trying to port a prepaid koodo account
(threads merged by computergeek541)
04-14-2019 03:39 PM - edited 04-14-2019 03:41 PM
04-14-2019 03:39 PM - edited 04-14-2019 03:40 PM
