transferred in failed
Geighbour
7 REPLIES 7
@Geighbour wrote:
yes my old service still working and i keep it until 4 day i have to transferred from
i did transferred but is failed and no paying for new service
Most times, this is the result of the text message sent by the old carrier about number porting not being responded to (old carrier's sim card must be in the phone) or of incorrect old carrier account information being provided (example: account number.  In any event, you're going to need to get help from a Public Mobile CSA.
Geighbour
Alexandf
@Geighbour
open ticket with PM support   At https://publicmobile.ca/chatbot.
have trouble with Chatbot: Private message CS Agent at:
Once ticket is submitted,(envelope icon on the top right) CS_Agent will reply you there.
Search results for "Number Transfer" (publicmobile.ca)
@Geighbour
Did you reply to the text from your previous carrier confirming you are porting over the PM? You got 90 minutes to reply.
If you missed this action, contact a CS_Agent.
@Geighbour can you provide more info?  is your old service still working?  you received the text from old provider and you replied yes?
mo1979ca
Are you trying to port your number or open a new account? Go tell SIMon the public mobile bot to open a claim to figure out what went wrong. Simon is "customer service"
RossN
@Geighbour hi I will PM you the number to call to reinitiate your port
