transfer issue
Ronan2
hi, there
i transferred my mobile from fuzz to public mobile, outgoing calls work, but incoming calls and SMS still do not work. it’s already over 24 hours, please help me resolve this issue.
thank you very much.
Frank52
Hello @Ronan2,
It looks like your phone transfer was not completed properly. If you didn't respond YES to the approve the transfer within 90 minutes, it can cause the transfer to get stuck. Not to worry though, I have sent you a direct message with the phone number that you can call to re-trigger the porting process. Please check your messages for the phone number to call. Unfortunately, I am unable to post the number in the community forum.
Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage )
OfficialDini
Hey @Handy1 ,
Would you be able to send me the details of the porting team by private message as well?
Thanks very much!
@Ronan2
You can try porting team for live support , will send you the number private message as we not allowed to post it here
if they are unable to help you need to contact support by
send  a  private message   To CS_Agent
