01-25-2020 12:36 AM - edited 01-05-2022 10:25 AM
December I earned a 10% badge which means $5 credit but on my self serve account shows only $2 credit, is it someshing wrong?
01-30-2020 12:29 AM
Thank you every one for answering my queston. I contacted moderator and got it fixed quickly. I got my $3 credit back.
01-25-2020 02:01 PM
I also received the $5 reward and it shows up under community rewards, but is not reflected in my "available funds" on the top of screen after login. Is this normal ? thanks
01-25-2020 10:04 AM
I had a similar thing happen. I contacted the mods and it was quickly sorted.
01-25-2020 09:20 AM
@yanzhiqiang Take a look at your profile the badge you got twice and/or the one displayed on the far left should be the appropriate level. As I see it in your profile it is top 10%...screenshot your account page just in case then contact the moderators.
01-25-2020 12:59 AM
@cavemantoronto wrote:
@yanzhiqiang wrote:December I earned a 10% badge which means $5 credit but on my self serve account shows only $2 credit, is it someshing wrong?
Wrong badges were given to some. They said they would honor the best communuty bagde for December if two were showing. Contact moderators using the question mark.
lol ... For Dec 2019 I got the full set (Oracle, 1%, 5%, 10%, 25%, and 50%) ... twice.
01-25-2020 12:42 AM - edited 01-25-2020 12:43 AM
