4 weeks ago
how can i convince public Mobile to use the the correct time. I'm in manitoba and we dont fall back anymore but public mobile incorrectly turned back the system clock 1 hour. if i manually correct the time, certain apps including banking, cease to function
4 weeks ago
Some people have suggested fixes. Maybe one of them will work for you: https://productioncommunity.publicmobile.ca/t5/Get-Support/Manitoba-Timezone/td-p/1471462
4 weeks ago
Same issue for me in manitoba
4 weeks ago - last edited 4 weeks ago
Have you checked for any OS or other updates for your device?
Does the OS let you manually set the time and timezone? Perhaps the app is using the combination to verify the time is valid. You may need to manually set the timezone to EST or some location that uses EST year around -- places in Mexico.
4 weeks ago
hi @cancelnow
looks like some are affected by the same issue. Please report this to PM support agent
You can submit a support ticket right at My Account and PM app using the Expert Messaging in one of these ways:
Support agent will reply within 2 to 4 hours. You will be notified via SMS/email or monitor here:
https://expert-messaging.publicmobile.ca
Remember: Support hours of operation: 9 AM to 10 PM ET
