09-15-2019 11:15 AM - edited 01-05-2022 07:06 AM
im able to send txt however im not receving any. help please!
09-16-2019 05:37 PM
@Tee1 wrote:I had to restart my phone this morning before it started working again. so much inconvenience!
Thanks for the update. Now we know a restart is indeed needed.
09-16-2019 01:33 PM
09-15-2019 11:53 AM
@Tee1 wrote:crazy! hopefully they figure this out soon.
thank you
Not likely.
After midnight ET of your day 11, try texting. If not still then try airplane mode. If not still then try restart. If you're willing, report back what worked when. You may not have to do anything. So we'll see.
09-15-2019 11:47 AM
thank you
09-15-2019 11:31 AM
@Tee1 it's a known bug in the system that the day after your 10 day roaming option expires you can't receive any text. Hopefully public mobile will fix it someday. By probably midnight tonight it will start working by itself!
09-15-2019 11:29 AM
09-15-2019 11:24 AM
09-15-2019 11:23 AM
yes my US roaming package just expired today!
only thing different everything else has been in placed forever
09-15-2019 11:22 AM
No i didnt just port my number. iv restarted twice now. yes im receiving calls
09-15-2019 11:22 AM
@Tee1 wrote:im able to send txt however im not receving any. help please!
Ok, a couple of things did you just port a number in? If no have recently purchased the US roaming package and have it expire?
09-15-2019 11:20 AM
@Tee1 did you just port your phone number? Start by restarting your phone!! Are you able to receive calls?
